A/F 'grid' logging V2.5
Jeff_Atwood
Post by Jeff_Atwood »
This may be fixed in V3, but I am tuning a PW0 and can't
use V3.
Problem: When recording the A/F ratio into the 'grid' all data
is recorded into the the low speed table regardless of
if the VTEC has been acivated. This is fine when tuning the
the low speed cam, but makes tuning the high speed
cam much more time consuming.
I understand that V2.5 is now a legacy/non-updated product.
I don't need the program to switch table automatically, I just
want to be able to force where the 'recorded' data ends up.
Currrently ALL recorded data ends up on the low speed table.
As it currently stands it takes me 3-4 times longer to tune
the high speed cam fuel vs the low speed cam using
the logger and manually calculating the required fuel adjustment,
or manually transposing the data from the low to high speed table.
Thank you,
Jeffrey Atwood
