Clutch Switch Installation
Posted: Mon Apr 18, 2005 10:52 am
by B18C_EJ8
Please forgive the noob question, but can I use the cruise control switch instead of buying/mounting another one? I've removed the cruise control unit from the engine bay because I never used it.
Anyone know which wires to tap for a 98 Civic EX?
Thanks for the help!
Posted: Mon Apr 18, 2005 9:51 pm
The cruise control is normally closed and the clutch switch needs to be normally open.
Posted: Tue Apr 19, 2005 5:40 am
by B18C_EJ8
I read somewhere that I can use the clutch safety switch, but doing so will make it so that I don't have to push in the clutch to start.
Is this true?
Posted: Tue Apr 19, 2005 9:53 am
You should use the recommended switch form a store like Autozone. The part number is JA413 for a Wells stoplight switch.
Posted: Wed Jun 08, 2005 4:10 pm
by JrCRXHF
i have the switch where can i get the cable
Posted: Wed Jun 08, 2005 5:08 pm
If you purchased the 3-step option form one of our dealers, they should provide you with the cable. If you have damaged or lost the cable you can purchase a new one from any of the dealers listed on our website.
Posted: Wed Jun 08, 2005 5:39 pm
by ak94gsr
ok, say but after buying the switch from autozone u can place it in the same spot as the cruise if u arent using this right??
Posted: Thu Jun 09, 2005 11:09 am
by turbo_civic_si
i would wire in a togle switch to select where you want the signal to go to. one way to start the car, and the other way to enable 3 step.
Posted: Sat Jul 09, 2005 5:25 pm
by B18C_EJ8
The only thing I could find on AutoZone's site was the wells JA4010... I found one at AdvanceAutoParts.com that was from a different manufacturer, but it was still a "stoplight" switch....
Still being a total noob, but think either of those would work?
