EGT temps
Posted: Wed Apr 06, 2005 5:44 am
by 2kblusiguy
I have a B20 with Type-R head w/Valve guides cut back slight porting, custom valves, Type-R intake, Hondata Gasket - port matched, 70 mm TB, AEM CAI, 10.4:1 comp, JDM 4-1, CTR cams.
MY question is: What kind of EGT temps are people seeing at cruise.
3000rpm - 60 mph - 1400F - 14.7 a/f
3400rpm - 70 mph - 1450F - 14.7 a/f
This is what I see on mine, I have played with timing and fuel but can not get it lower then those numbers.
I know that your EGT will be the highest at stoich but is this too high...???
thanks
Mark
Posted: Mon Apr 18, 2005 7:43 pm
by Paluce
That sounds about right. Is you gauge tapped 3-4" from the head?
I'm sure your car goes open loop when it gets near 1550-1600F on cruse.?
Posted: Tue Apr 19, 2005 4:55 pm
by 2kblusiguy
Yes my EGT is close to the head. I have a sensor on CYL 2 and 3. they are both about two inches from the head. I have played around with the timing in the highway cruise area and have got it to stay around 1425-1440 at 75 or so. but that is about as low as i can get it thus far. as far as the 1550-1600 temp, i never see anything that high. on a full power pass i see 1300-1325. which is about perfect. I would like to see 1380, but that will take a little tuning. I'm not big into the dyno thing because, of all the variables that can throw you off, so i prefer road testing with actual loads on the engine, that the engine will see. it seems to work pretty good for me, so far and a whole lot cheaper. thanks
mark
Posted: Tue Apr 19, 2005 8:12 pm
by Paluce
ya, timing has a lot to do with EGT temps, as well as location. What kind of timing are you running?
Posted: Sun Jun 05, 2005 5:23 am
by 2kblusiguy
As far as Timing, I am from about 3,000 rpm's up around 45 degrees, under low load cruise condition, 3-4 column.
with these settings I see about 1410 f, at 70 mph.
Posted: Wed Jun 08, 2005 6:36 am
by 02SilverSiHB
I have a k series...but with mine I would see 1350. But on some days I would see it drop to 1200 at those speeds
Posted: Sat Jun 11, 2005 7:30 am
by 2kblusiguy
02 silver SI,
wow i wish i could see those numbers, soon i hope. i'll get it.
where is your EGT probe located???
Posted: Fri Aug 12, 2005 10:54 am
by 2kblusiguy
BUMP
I have re-tuned and I am now at 47 degrees at cruise.
3900 rpms - 75 mph - 1410f EGT
Anybody else have EGT numbers, N/A
tks
