Honda B18C1 with LM-1 Wideband Lambda Conversion Table
Posted: Tue Apr 05, 2005 4:28 pm
by 7rrivera7
Is there anyone tuning Honda B-series engines with the Innovate LM-1 Wideband? If you have nailed the conversion tables for the LM-1 and ROM Editor, please let me know the values you are using for the LM-1 output and the ROM Editor table because I'm close but still not consistant.
Thanks!
Posted: Thu Apr 07, 2005 9:11 am
by 2kblusiguy
I'm using an LM-1 and used the same conversion table used in RomEditor. I just programmed it with the same values it had in RomEditor as the preset, and then downloaded it to the LM-1 Works fine for me.
Posted: Thu Apr 07, 2005 4:35 pm
by 7rrivera7
Ok, great. Which table did you use from the defaults in ROM Editor?
Posted: Fri Apr 08, 2005 11:08 am
by 2kblusiguy
in RomEditor:
File > Settings > Lambda > Edit Conversion Table
Quick Select > Custom
Then just use these values to setup the output of the LM-1. output one or two.
ie. 0 =8.820 a/f
4.5 = 22.050 a/f
I also did a little math and made the second output output a 0-1 volt output to the Autometer cheapy a/f guage i have making the very middle stoich and the first green light 12.94 a/f, so i can look and tell what ratio i'm at at a glance. Just for driving around without the laptop and that bulky controller.
mark
