K24 TSX Basemap adjustments
nintalpine
Post by nintalpine »
Hi everyone, this is my first post here. I am very new to Kpro and Kmanager so I have been doing my best to learn how to get my base map dialed in so I can get the car to the tuner. I ran the vehicle (k swap ek hatch) for around 4 minutes and will include the log. Around the 3 minute mark the ecu advanced the cam by 33 degrees while at idle, leading to a surge to 1900rpm. My setup is a ported rbb head, rbc IM port matched to a 70mm throttle body and 3 inch CAI from hybrid racing. Exhaust is 4-2-1 k tuned 409ss header, full stainless 2.5 inch setup with 200 cell cat, resonator, and oval muffler. I have only adjusted the low speed fuel table so far in order to get it to run less lean. I have IACV disabled so i will need to adjust my throttle plate to get my idle down to 900 from the current 1200. Logs are attached. Thanks and let me know what more info is needed
CalibratEd
Re: K24 TSX Basemap adjustments
Post by CalibratEd »
Welcome to the forum,
Post the calibration file as well.
-Ed
Instagram: calibrated.tuning
nintalpine
Hi, this should be the correct calibration attached. Thanks
