S300 v1 software issues
Haster
Post by Haster »
Hello, my old laptop broke down, and I bought a new computer with Windows 11 software. It's now unable to connect to my S300 v1. How can I fix this?
Re: S300 v1 software issues
Haster
Post by Haster »
computer Version Windows 10 64-bit operating system
How to Turn Off Memory Integrity
1. Open the Start menu and type Windows Security, then press Enter.
2. Click on Device security.
3. Under the Core isolation section, click on Core isolation details.
4. Toggle the switch for Memory integrity to Off.
5. Restart your computer.
Haster
Post by Haster »
I checked, and it's currently off.
This says you are using Windows 10
Haster
Post by Haster »
Yes, my laptop is currently running Windows 10 64-bit, and it's unable to connect. What should I do?
So is this a different laptop than you originally asked about, as you said it had Windows 11?
Haster
Post by Haster »
Sorry, I made a mistake, it's Windows 10.
What shows up in the Windows device manager when you plug and unplug the USB from the s300 while in the vehicle with the ignition in the on position.
Haster
Post by Haster »
I found that it is connected to my computer, but I cannot adjust any ECU settings through the laptop. The display doesn't show any numerical changes when the car is started.
Is J12 cut on the ECU?
Haster
Post by Haster »
Ecu is 37820-P30-010 J4 cut
Haster
Post by Haster »
I took two pictures, please help me confirm.
