FlashProManager 4.7.6
FlashProManager 4.7.6 (7 Aug 2026)
  • [FL5/DE5] Fixed radiator fan temperature settings
  • [FL5] Fixed pops and bangs for 2026 models
Download here
Please only post in this thread if directly related to the software release. It is not the place to request features.
FK8_Hoonigan
Re: FlashProManager 4.7.6
Post by FK8_Hoonigan »
May want to check the Compare feature on v4.7.6, with multiple tables and fields changes, most of list is NULL.
Tested previous versions, compare feature its working fine on those.
GARIX Tuning
2021 R-39464
https://dot.cards/garix
Please post the calibrations you are trying to compare.
jeffx
Post by jeffx »
I checked it myself with just using a baseline calibration and then altering it (these files are attached). The compare function in 4.7.6 shows no differences at all. (no screenshot attached, because it's literally an empty table of output on 4.7.6)
On an earlier version of FPM, it shows this (which is correct)
mike_99gsx
Post by mike_99gsx »
I can not get my Flashpro to update its firmware with 4.7.6 I have tried uninstalling the software and reinstalling. Normally the prompt immediately comes up for me to disconnect the OBD2 harness and do it but nothing will pop up. Flashpro is currently on 4.7.5
SN: FP-ITS-420522
mike_99gsx wrote: Sun Aug 16, 2026 4:58 pm I can not get my Flashpro to update its firmware with 4.7.6 I have tried uninstalling the software and reinstalling. Normally the prompt immediately comes up for me to disconnect the OBD2 harness and do it but nothing will pop up. Flashpro is currently on 4.7.5
SN: FP-ITS-420522
The firmware was not updated in this version.
Our software engineer is looking into the compare issue.
Fkay8
Post by Fkay8 »
Are there any updates regarding the status of this issue?
dmoraroj
Post by dmoraroj »
jeffx wrote: Fri Aug 14, 2026 8:55 pm I checked it myself with just using a baseline calibration and then altering it (these files are attached). The compare function in 4.7.6 shows no differences at all. (no screenshot attached, because it's literally an empty table of output on 4.7.6)
I have this same issue with this version. "Compare" option is not working anymore.
Please email support@hondata.com the two calibrations you are comparing. If you can, include a link to this thread.
It should be fixed in the next release
