I was thinking and -
Posted: Sat Mar 26, 2005 11:52 pm
would it be possible on one of the future updates to add a feature that you could simply click a button to adjust the fuel table to what is suggested after a datalog instead of having to go through and do it manually.
also, is it possible to have a feature that could calculate your mpg instant and average?
I've been doing dozens of datlogs and making the suggested fuel adjustments but it seems the next data log after the next all need major adjustments. I've made the adjustments leaving it on all tables and it seemed I still wasn't getting anywhere and I tried looking at the cam angle ang adjusting the fuel for that single table and still keep needing adjustments anywhere from -1 to -27. I finally started doubling the suggested adjustments using all tables and after a few datalog with this method I've gotten it alot better but still not quite the 13 to 13.5 range thats desired. it still seems to dip down to the mid 12's at times.
here is a log and the kal I've been messing with, let me know what you think
BTW this kal has had a little timing advance added since I was getting comfortable with the fuel.
Are there any cam angle adjustment you would suggest or must I purchase dyno time to mess with cam angles?
thank you
edit: on this log you can se 1st through 3rd are fine af wise but 4th gets very rich and if you look at the afcmd in sensors you can see that it is in the low 11's at times WTF
thank you
