2008 Civic SI Sedan
Posted: Thu Apr 30, 2026 5:25 pm
by web35
I see two options for ECU input from the TC module. It appears that most go with disconnecting the ELD, A23. However in your help section there is a statement that the the B29 EGRL - EGR lift input is Normally unused. Can I assume that either will work the same or is one better?
Re: 2008 Civic SI Sedan
Posted: Fri May 01, 2026 9:47 am
Either can be used and work the same.
