Question about Disable P0134 in Kpro manager...
Dominic..
Post by Dominic.. »
Hello.
I would like know why disable P0134 (O2 sensor response)
is not available in Euro Civic Type R ECU ?
Thank you for help.
I'm not sure that the Euro ECU generates the P0134 error code, or the error code mapping might be slightly different between the JDM/US and Euro ECUs. If you are getting the P0134 error code in KManager with a Euro ECU, use a scan tool and tell me what the P number is as it may be different from KManager.
Dominic..
Post by Dominic.. »
thank you for info!
Sorry, but I don`t have this error,
I ask about it, becouse for my race car I want disabled primary O2 sensor.
But how can I check which error generate Kpro?
Can I disconnect primary O2 sensor and check which error will be?
Thank you
Dominic..
Post by Dominic.. »
I would like ask you also,
you are planing in future add folowing function for Kpro.
1. Calibration of knock sensor ( it is important for high boost turbo, forged pistons, big clearance ,etc)
2.Function like auto retard ignition when detect knock ( retard for value in degress which you can yourself adjust)
thank you.
Just set the ECU to open loop and disable the o2 sensor heater errors, and you also may need to disable the OBDII functions.
I won't comment on future development but your requests are noted.
