NOS issue with USKpro on a Euro EP3
Posted: Wed Feb 23, 2005 8:19 am
I have been working on a Euro EP3 that has been happily running the USKpro for over a year and am soon to do the same conversion myself to my car.
I have wired up a NOS dry kit as per hondata instructions:
http://www.hondata.com/kpronitrousdiagram.html
But we have an issue that is a little bit strange and need some inside guidance.
The actual output control is fine and functions as expected but the problem is the arming input.
We can only utilise one input as you know and on the US cars E16 is the PSP input. On the Euro cars it is the same sort of sensor but for the EPS (Electric Power Steering load sensor.)
Now when we arm the circuit (with the input inverted) it all works fine.
When we disarm the circuit when the steering wheel is released i.e. under zero load...the NOS arms itself. As soon as you move the wheel it disarms. (Inverting the arm signal gives the opposite effect) We obviously can?t use this as when it arms and if you?re not actually using the NOS you will end up damaging your engine by overfuelling and adjusting ignition so it?s a bit of a non-starter.
Now I know this has been utilised in the UK before and in Europe on other EP3's but I am really struggling to find information to overcome the issue.
The only way around this at the moment will be to physically plug in your laptop and enable NOS when you want to use it...but that?s a bit of a pain.
Any ideas and assistance would be appreciated.
Paul
Paul
