Converting US PRB RSX-S maps to UK PRA CTR maps ?
Hadi
Post by Hadi »
Is there any way to convert US PRB maps to be use on UK PRA ECU ?
thanks
foobari
Re: Converting US PRB RSX-S maps to UK PRA CTR maps ?
Post by foobari »
Hadi wrote:Is there any way to convert US PRB maps to be use on UK PRA ECU ?
Copy-pasting the tables from RSX maps into Type-R base map works.
foobari wrote:Copy-pasting the tables from RSX maps into Type-R base map works.
If you cut and paste the indexing will be wrong. Why do you want to use the RSX tables?
Hadi
Post by Hadi »
coz am thinking about boosted my 2003 CTR with Greddy turbo kit, Cybernation or revhard (stage 1), and no one got the calibrations for those turbos, so am thinkin of using the RSX-S one.
Hadi
Post by Hadi »
any ideas ??
We do not recommend cutting and pasting tables between different types of ECU, nor hacking the calibration file to load as a different type. The different ECUs use different compensation tables so the same values for each ECU will not produce the same results.
Ultimately you need to tune the ECU to the engine.
Hadi
Post by Hadi »
what about changing the ECU numb from 3 to 2 , and change the low speed rpm from 750 to 800/8100 to 8000 ? and the high speed rpm from 5750 to 5800 ?
thanks
