hondata jrsc @ WOT under boost problems tuning
Posted: Thu Jan 27, 2005 8:16 pm
my cars been at autowave for the past week. application is a jrsc civic si b16a2@11.5 psi with the mvm stepper pulley with hondata S2B and RC 550s. Mike is the tuner if your fimiliar with him and we've been trying to diagnose a tuning problem@WOT for the past week. day one of tuning resulted in 127whp and disappointing problems. i have not been there for the other 5 days, but, Shawn at autowave has been calling me everday about the results.
anyways, idle and acceleration is fine except@WOT, where there is bogging in boost. before the tune, we put in some colder plugs. our first problem was that we were amazed that the stepper pulley put out almost 12 psi, so, we swapped to the 3 bar map in. it still did not solve the problem so, we checked the cap, rotor, and coil. they were all getting toasted, so, we replaced them.................it didnt solve the problem. i remember the cat was clogged so they dropped out the cat and it seemed to free up a bit. we cleared the cat up a bit and the problem is still persisting@WOT under boost. We popped the valve cover and found a few tight valves, so, we adjusted them. compression and leakdown shows two cylinders are a little weak, but, not life threatning. after $748 on the dyno, im just going to bring the car back home tommorrow morning and start troubleshooting myself to save time and money. Ill give the TPS a look when it gets here. gonna check all wiring from the ecu to under the hood.
im also thinking, weak valve springs. i found a set of oem valve springs and retainers. i think i might pick em up and see what goes on with that too. i was also thinking timing belt, but, that is a long shot. maybe vacuum leaks, but, vac gauge shows a steady 20inhg at idle? also, the JR FMU is still connected, but, with the vac source unplugged from the fmu and fuel lines still running in and out to the stock fpr. source of vacuum is also plugged. gonna spend my weekend checking all sensors and wiring.
What can the problem be. the tuning seems fine, the blower seems fine. I thought of belt slippage, but, there is no drop in boost.
