KManager Feature WishList...
Posted: Mon Jan 17, 2005 5:06 pm
by RSXpilot
Just a couple suggestions:
- After clicking in the "Graph" window, allow the Left & Right arrow keys to move frame by frame in that direction. The current effect is to switch templates (as do the up & down arrows). Leaving the up & down arrows to switch templates would be ideal.
- While dragging in the "graph" window, when you reach either edge of the window, scroll the graph in that direction.
- Some way to load 2 .kal files and compare them, highlighting (or only showing) the differences in the tables.
Thanks for producing a GREAT product!
Posted: Tue Jan 18, 2005 8:51 pm
by locash
In addition..
The ability to view datalogged a/f ratio/difference from target lambda/etc like the older S200 systems.. I feel that would cut tuning time down a bit, and make the transition between the two softwares that much easier for those of us who tune both systems..
Posted: Wed Jan 19, 2005 12:45 am
by foobari
One very nice feature for us Euro Type-R tuners would be the possibility to choose the SO2 units to be either volts, or direct A/F readings using a configurable mapping table (voltage->A/F). This would be very handy when using a separate wb-lambda connected to the SO2 input (e.g. AEM UEGO outputting 0-5 volts to the ECU's SO2 input)
Anyway, great product!
Another suggestion...
Posted: Wed Jan 19, 2005 11:29 am
by RSXpilot
How about including the Version # in the header comments of the .kal files?
As there can be problems using a kal from a different (earlier) version, this might be useful information.
So instead of this:
Code: Select all
; Hondata K-Manager Calibration
; Created 6/16/2004 3:02:10 PM
; Don't edit this file directly
there could be this (or something similar):
Code: Select all
; using Version 1.1.5.0
Just a thought.
And another...
Posted: Wed Jan 19, 2005 11:52 am
by RSXpilot
What about having the capability to display a horizontal reference line in the Graph window?
Foe example: You want to see how your AF compares to 13.2.
So in the Graph window you scroll until you find a spot that has an AF of 13.2 (or thereabouts), then right click & select "Create Reference Line".
Now you can quickly scan the datalog and visually see the deviations from that reference.
Even better, might be the ability to set the value of the reference line using a text box.
Posted: Sat Feb 19, 2005 6:03 pm
by locash
Just wanted to say "thanks!" to Hondata for the lamdba overlay display! Also, I never even thought about the lean protection, that is damn sweet..
