? on tuning boost motor n/a first
Posted: Fri Jan 07, 2005 9:48 pm
by Super-Tuner
My question is yea your suppost to tune a boosted motor n/a first,but when you install your turbo system how can you tune the motor n/a before getting boost. Is their a way to just keep the wastegate open or would it be ok to take the spring out would that work? thank you
Posted: Wed Jan 12, 2005 10:57 am
by Clutch
Yes, you will be fine by just taking the wastegate spring out. I tuned my n/a first without the turbo on, tuned again after I put the turbo on.
Later
Posted: Wed Jan 12, 2005 11:17 am
by Super-Tuner
yea, but doing it that way wouldnt it affect the airflow charcteristic's and change you a/f's a little?
Posted: Wed Jan 12, 2005 11:37 am
by Clutch
That is why I re-turned after putting the turbo on. My n/a portion was pretty close to dead on what I wanted after the install. I just had to tweak that area a little. Made my boosted portion a lot easier to tune. I took the route of tuning before the turbo because I didn't like the idea of running mine through that small dump tube. Just my feeling. Nothing wrong with the other way.
