at the moment i am putting a b16a2 into a mini front end, the engine was taken from a 99 civic coupe, but it was in a front end smash, i recently got hold of full ecu wiring diagrams and inputs/outputs etc and rewired the original harness to suit, but! its still listing faults with the 02 sensor and its not givin the +12v output for the pre-heat in the coil to raise the temperture for it to work properly and excesive bursts of black fumes under load, on the other hand i am at the stage where i would like to up the power slightly and after hearing about hondata sytems require a little advice, ive been looking at DTA, and Dastek piggy back modules and ecu systems but are stupidly priced and a ful re-wire is involved, but which hondata system is there that would replace my p2t g11 ecu, and allow me to program to suit on rollers?
any help or minor advice would be grateful
many thanx
require a little advice and help ?
if it itche's
Scratch it.
Scratch it.
