Hondalogger keeps crashing!
Posted: Tue Dec 28, 2004 6:37 am
by s88hon
As the above says... It works fine for 5 minutes then I get a 'windows blue screen' and the laptop reboots itself!
Can anyone help? I am using XP and utilising a Toshiba (I have a 'satellite' laptop) usb-serial port adaptor.
I think the error was something to do with temp-locals????
Posted: Tue Dec 28, 2004 7:21 am
by DaX
Try using a Keyspan USB to serial adapter. We had problems with connectivity while not using this brand.
dataloging software keeps crashing
Posted: Thu Mar 17, 2005 4:55 pm
by tboostdsi
I am having the same problem, runs fine, connects fine, records fine but after a few minutes, blue screen comes up and computer restarts.....anybody know how to fix>?????
Posted: Thu Mar 17, 2005 5:15 pm
What brand USB adapters are you using?
Posted: Thu Mar 17, 2005 9:53 pm
by tboostdsi
brand is iogear usb to serial.....also, it connects sometimes right away, others it wont connect...just says connecting .........laptop is a dell insperion 2600
Posted: Fri Mar 18, 2005 10:22 am
We do not recommend using any USB to serial adapters unless it is the Keyspan USB adapter.
Posted: Mon Mar 21, 2005 6:27 pm
by 01 LudeDude
I have the same problem with my laptop. If I pull down the file menu, goto settings and then just OK out of that window, then connect and it works every time. BUT, I can only run it for 1-2 mins then it crashes and my laptop reboots. I'm wondering if it's an XP thing, so I'm gonna format the laptop and dual-boot with Win98 and see if I still crash in 98. I'll let you all know, unless this has been tried already and if that's the case let me know so I don't waste my time formatting
Posted: Mon Mar 21, 2005 8:14 pm
by tboostdsi
when re formatting the laptob, any instructions on how to reformat it???? i talked to a guy at comp usa and he told me thats what i need to do to fix the problem about the blue screen coming up and all.... do you need the back up disk?
Posted: Tue Mar 22, 2005 7:12 am
by DaX
01 LudeDude wrote:I have the same problem with my laptop. If I pull down the file menu, goto settings and then just OK out of that window, then connect and it works every time. BUT, I can only run it for 1-2 mins then it crashes and my laptop reboots. I'm wondering if it's an XP thing, so I'm gonna format the laptop and dual-boot with Win98 and see if I still crash in 98. I'll let you all know, unless this has been tried already and if that's the case let me know so I don't waste my time formatting
We tried the iogear with windows xp and windows 98 with the same resutls...connecting then blue screening after about a minute. Get the keyspan...ZERO issues.
Posted: Wed Mar 23, 2005 11:04 pm
by tboostdsi
yep, i just got the keyspan. i have no problems, it fixed all my previous problems....i am very pleased now. THANKS ALOT!!!!
Posted: Wed Mar 30, 2005 12:15 pm
by sander
MUST use keyspan, i had countless problems with other usb adapters. i have had ZERO issues with keyspan
-s
