Won't start after FlashPro update.
Posted: Sun Dec 07, 2025 3:08 pm
by GhostieTR
I have a 2017 FK8 and it now won't start after update.
I updated my program and then my Flashpro. I wanted to put my fk8 back to factory but now its stuck in Recovery mode. I read that I have to unplug EVERYTHING and then plug it back up to try again.
I also deleted my old tune from the Pro as well.
After reinstalling my old tune and retrying back to stock, it still won't turn over. It'll show "Recovery Mod" and then switch to green but it still won't start.
Any help on want to do would be appreciative.
Re: Won't start after FlashPro update.
Posted: Sun Dec 07, 2025 4:05 pm
by GhostieTR
Now it says ! Jailbreak: Yes
Posted: Mon Dec 08, 2025 3:15 am
by Rares
Most likely your battery is discharged (less than 11.5-11.6v) and the reflash cannot be completed. Connect a charger to the battery, but it is very important not to disconnect the battery even for a moment.
After charging the battery a little, you can try to reflash again.
Posted: Mon Dec 08, 2025 4:28 am
by GhostieTR
I tried that a few times now and still the same issue. Battery is currently 12.54.
I'm currently trying to just put it back to Stock and it still won't start. When I push the START button after the time is completed, I'll push it, it beeps at me, Ill push it 2 more times and then the ignition finally turns off.
Posted: Mon Dec 08, 2025 8:33 am
What is the serial number of the FlashPro?
Posted: Mon Dec 08, 2025 8:42 am
by GhostieTR
FP-CTR-US-354444
Posted: Mon Dec 08, 2025 9:09 am
by GhostieTR
Hondata wrote: Mon Dec 08, 2025 8:33 am What is the serial number of the FlashPro?
FP-CTR-US-354444
Posted: Mon Dec 08, 2025 10:08 am
Posted: Mon Dec 08, 2025 10:35 am
by GhostieTR
Spunkster wrote: Mon Dec 08, 2025 10:08 am With everything plugged in and the ignition in the on position, go to the Help menu and click on “send feedback”. Include a detailed description of the issue.
I did last night.
Posted: Thu Dec 18, 2025 10:23 pm
by GhostieTR
Update. The FlashPro cuase an internal voltage code that wouldn't allow the car to start. Had to get a reader to clear it.
Posted: Fri Dec 19, 2025 7:54 am
by jeffx
For the sake of completeness (and for anyone searching due to a similar issue in the future), can you share what was the DTC and what type of tool was required to clear it?
