S300v3 Intermittant USB Connectivity + Other Issues
7rrivera7
Post by 7rrivera7 »
- serial number of the s300 inside the ECU - 34580
- version of software being used (Help, About) - 2.8.9.0
- the calibration (as an attachment) - attached
- a datalog of a problem (as an attachment)
- what sort of vehicle you have - Civic
- what sort of ECU you are using - P28
- anything about the car which has been modified from stock which may affect the ECU (don't include what sort of rims you have nor stereo etc).
- a specific description of the problem - ECU will not ERASE, cannot upload a new calibration and USB connection is intermittant but mostly will not connect. When it does connect, I see the S300 in device manager and then it disconnects and gos away
Re: S300v3 Intermittant USB Connectivity + Other Issues
Have you tried a different USB cable?
7rrivera7
Post by 7rrivera7 »
Yes sir with the same result. I also used both cables on another S300 in the same ECU and both connected fine
Post a picture of the top and bottom of the s300 circuit board and one of the inside of the USB port.
7rrivera7
Post by 7rrivera7 »
Attached
You might try cleaning the inside of the USB port with a toothbrush and isopropyl alcohol.
7rrivera7
Post by 7rrivera7 »
Still having issues. Although I can connect, I cannot upload or erase the ECU
7rrivera7
Post by 7rrivera7 »
Connected and online
7rrivera7
Post by 7rrivera7 »
Hi, so what's the next step? Repair? Replacement? Cost?
Send an email to support <at> hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
Include a link to this thread.
