K24z3 with Skunk2 drop in cams
Posted: Sun Nov 16, 2025 4:11 pm
by DFoster0
Good afternoon,
I'm getting multiple misfire codes when car is running. Hope someone can look at the data log and give some guidance. I pulled the cam cover off and timing looks good. Thanks
Re: K24z3 with Skunk2 drop in cams
Posted: Mon Nov 17, 2025 9:58 am
What vehicle is this and what modifications have been done?
Posted: Mon Nov 17, 2025 3:43 pm
by DFoster0
2011 tsx motor/2012 si transmission with 09 tsx ecu...in a 2009 Honda fit
Type s oil pump, 2.5 exhaust, aem intake, and the skunk2 drop in cams
Posted: Mon Nov 17, 2025 4:07 pm
Does it have an aftermarket clutch and flywheel?
Posted: Mon Nov 17, 2025 6:10 pm
by DFoster0
Yes it does action stage 1 and lightened flywheel
Posted: Mon Nov 17, 2025 8:46 pm
by DFoster0
I did a little research and seems the flywheel is causing the error. I disabled the code under calibrations and it seems to be fixed now.
