1000cc
niascrew
1000cc
Post by niascrew »
I am trying to tune a 1000cc injectors on an h22turbo 8:1comp, 89mm bore gt30 turbo, car doesnt idle does anyone have a map similar to setup 1000cc injectors thanks
NIAS PERFORMANCE
3059 SOUTHWEST BLVD
KC, MO 64108
ACL BEARINGS KIT $79.99 SHIPPED
Silverbeast
Post by Silverbeast »
Larger injectors usually require a little more timing to idle. Try doing that and increasing the duty cycle on the IACV until you get it started.
JKOBD
Post by JKOBD »
Also to add, you will probably want to try and get them to idle around 900rpms with roughly a 13.5:1 AF because of the larger dead time associated with those injectors. My street car idles 1600s around 1k rpms and 13:1 AF.
