class 2 data.
bigdog1
class 2 data.
Post by bigdog1 »
I cxan no longer get a class 2 data signal out of this 00 prelude [std trans]after hondata pcm installation.......help!!!!!!!!
You will have to give more details....what ecu are you using, what have you done exactly...etc.
bigdog1
no class 2 data 00 prelude;
Post by bigdog1 »
neer as i can tell its a s200 .the hondata ecu used four of the 5 connectors from the factory harness i suspect the the class 2 data may have gone through the connector not currently used?I dont know much about these conversions,your help is truly appreciated.doug
I'm sorry, but you still have not priveded the requested information.
