Hi!
I have set my torque tables for maximum power with no wheel spin this summer... Now it's getting colder here at night and those tables are not stopping the wheel spin anymore...I wonder if it would be possible to have the torque tables values linked to IAT values with a % correction table? So when temps are in the low IAT if I think I would need 540 torque instead of 600 it would be automatically lowered to 540 if I selected a 10% torque drop in the IAT correction table etc... It would need at least the 100% TPS portion to get this correction...
I'm willing to be a tester if needed :)
Torque tables with IAT compensation suggestions DE5
Re: Torque tables with IAT compensation suggestions DE5
I have achieved that sort of goal with the boost by gear tables. I have one that's like a "valet" mode and the remaining 4 of them are designed for varying grip levels ranging from cold/wet conditions all the way to R compound tires/full beans
then you still have the 3 throttle maps which you can further massage
Thanks jeff!
I thought about that option too but I think it would be better if it was automatically done by correction tables than to play with different maps that I will forget which maps do what etc... :)
