reflashed K ECU into an EG coupe
mr. mis-shift
Post by mr. mis-shift »
what would we need in order to get a #4 reflashed ECU working into an EG coupe with a K swap.
assuming that the following are not available
-immobilizer
-ignition
we only have the original key and ecu. could u help? thanks.
mis-shifter
You would have to upgrade to the K-Pro. As long as it has a previous reflash, the cost is $500 to upgrade.
mr. mis-shift
i see thanks.
we've managed to find an immobilizer an ignition, is the KPRO still necessary?
Yes you still need the K-Pro to properly tune the engine since the fuel system has completely changed, and there are sensors that are no longer connected to the ecu.
