first start... please look at my log?
wannab
Post by wannab »
I just started my car with a base map from ha. Would anyone be willing to look at my logs and see if anything seems weird. I don't know how everything should look yet I'm just learning. I think i need to enter the correct values for my wide band because it reads 13 in hondata and 11.5 on my aem gauge. o2 is wired in and have an ethanol sensor. i removed the oem o2. so i just have the aem wide band. It will go to a pro for tuning I just want to make sure its safe to get there.
Columrson
Re: first start... please look at my log?
Post by Columrson »
Your AFR mismatch is normal if Hondata isn’t set up with the correct wideband calibration. The AEM typically outputs a linear voltage that needs to be entered in the software (0V = 10 AFR, 5V = 20 AFR, depending on the model). Double-check the calibration table in Hondata and match it to your AEM specs.
