REQUEST: FPM Wiki hosted by Hondata?
Posted: Tue Aug 26, 2025 8:04 am
Just a suggestion, would Hondata consider hosting a wiki for FlashPro manager? I know there's a pretty comprehensive set of documents built into the app but a lot of new tables and stuff (especially for the FK8/FL5/DE5) are scarcely documented - sometimes if you're lucky you can find a mention of them in "what's new" notes but going through those isn't exactly convenient.
I would like to see a single source of truth, fact-checked by Hondata to explain the tables and parameters, what the values and axes represent (it's not always obvious on FlashPro Manager), perhaps containing some simple guidelines on the typical range of values as a sanity check. Much of the content can be community-generated and of course if anything is wrong or incomplete, then Hondata staff can fill in the gaps or correct whatever is necessary. I think it would be a very helpful resource for all Flashpro Manager users.
There is useful information to be found in the forums but it's not always easy to locate it.
thank you for all of your efforts, and I hope you consider this request.
