krpo v4 bluetooth connection intermittent drops issue samsung and apple
corlon
Post by corlon »
i'vel always had bluetooth connections issues since day one with kpro. at first i was just using my phone, a samsung. i then connected an ipad. same intermittent issues. either device always connections, but almost always disconnects during a drive. i can back out of hondata and then reopen and this will work a few times, but then stops connecting. i will restart the phone or ipad when it stops connecting, but will not reconnect with kpro. wondering what i can try to resolve this issue? please let me know what other information is needed.
Re: krpo v4 bluetooth connection intermittent drops issue samsung and apple
If you remove the lid form the ECU, does it make it any better?
corlon
Post by corlon »
removed the cover and went for a drive. my samsung phone stayed connected for about 13 minutes and then would not reconnect. these messages come up when i try to reconnect.
From Help, About, what is the version of KManager you are using?
corlon
Post by corlon »
version of kmanager
ecu/hondata ecu info
Are you using resistor or non-resistor type spark plugs?
corlon
Post by corlon »
resistor type - BKR7EIX
send and email to support <at> hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
Include a link to this thread.
corlon
Post by corlon »
email sent.
