fuel tip in work around
FlashPro questions & answers specific to the 2007-2008 Acura TL
reallyflyguy
Post by reallyflyguy »
This might be reaching. I finally got my wideband installed and I've been tweaking my afr. I notice that the moment I touch the throttle I typically get a brief lean spike. 15-16.1
I've messed with everything and can't seem to clean it up.
Is there something I'm missing or could a fuel tip in adjustment be added to the table?
reallyflyguy
Re: fuel tip in work around
I know I should have uploaded the info, sorry...my bad.
If you wouldn't mind looking to see if I'm an idiot or what. The lean spike is bugging my OCD.
I have flashed a bone stock tune in to see if that changed anything and it does not.
reallyflyguy
Info, 3.5 type S with 80mm throttle body, no EGR, no cats and CAI
I've tried raising and lowering my L/min throttle air flow
played with injector cut and restarts
played with ignition tip in
played with fuel cut
played with richening areas
I think I've tried all areas and keep getting the same results
I know in S300 there is the ability to tip in the fuel for something like this
All you can do it try adjusting the throttle flow vs opening table.
reallyflyguy
ok, I'll try again.
thank you
reallyflyguy
So I noticed something under calibrations
Ignition section
warm up ignition retard enable(this has a check box)
throttle tip in retard
ignition retard gear compensation (this has a table)
-these are what are listed...
Throttle tip in retard has no table attached, yet you can see it's supposed to have something attached..
or so it appears
I think that's the adjustment I'm missing
I'm using the most recent beta version
