possible fried kpro/ecu?
Posted: Sat May 24, 2025 4:46 pm
by TomsCG6
Hi,
1999 civic ex
k24a2
gt35r turbo
aem wideband
1000cc injectors
skunk2 4 bar map
acuity hall effect tps
90mm tb
skunk2 ultra street intake man
1320 sidewinder header
44mm tial wg
09 tsx cam with 50 degree vtc
kpro version 4.6.1.0 build 4083
sn 65260?
ecu 37820-pnd-a58
ok so here is the issue, a week ago my wiring harness decided to make love to my exhaust which is wrapped in fiberglass header wrap and melted together while i was driving. car died. after some investigation i discovered the harness and said problem. so i replaced the harness and a few sensors that fried and of course all the corresponding fuses. car starts up and runs pretty good but i was dataloging today and the log was weird to say the least. im attaching the log and my cal. also if someone could look at my map and see if it needs any tweaking or at least let me know if its unsafe to run please.
also before all this happened i have not been able to get this thing to idle for the life of me. wants to idle around 1500-2000, once and a blue moon it will drop to 950 and be fine for a street light then the next light right back to 2k. any help on that would also be appreciated.
thanks
Tom
Re: possible fried kpro/ecu?
Posted: Sat May 24, 2025 4:48 pm
by TomsCG6
forgot to attach these
Posted: Tue May 27, 2025 8:59 am
please describe the problem you are having with it now.
Posted: Tue May 27, 2025 7:32 pm
by TomsCG6
It studders at random times like it got turned off for a split second. And when I'm trying to log or do a pull the display will randomly show all sensors maxed out red for a split second. So I'm not sure if it's the ECU or something else. Has anyone been able to see if my map is ok to run? The datalog number 3 shows what I'm talking about better.
Posted: Fri May 30, 2025 12:55 am
by TomsCG6
Also today I noticed while logging my vtc isn't working. Cam stays at 0° throughout the rev range. Even when camcmd is asking for XX°. I'm guessing the solenoid got fried?
Posted: Fri May 30, 2025 11:09 am
As this was an install kit sold to HA Motorsports you should have them test it for you and if the ECU is damaged you can provide them with a replacement, and they can install the K-Pro into the working ECU.
