Flash Question
FlashPro questions & answers specific to the 2008+ Accord, Americas and international
rainy187
Flash Question
Post by rainy187 »
before when flashing the car, the red light on the flash pro turn on and the parking "P" will change to mix digit. when the light turn off, the digit change back to "P" and you are able to press the engine button to shut it off.
but now it doesn't do that anymore, even after the red light on the flash pro turn off, the mix digit stays, and you need to press and hold the engine button to turn it off.
Is this normal?
Re: Flash Question
Is it working normally other than that?
rainy187
Re: Flash Question
Post by rainy187 »
seems like the RPM didn't get flashed, i set it at 800 but it seems like using the old calibration of 720 still.
rainy187
Re: Flash Question
Post by rainy187 »
it just seems like it can't completed the flashing process, because it wasn't like this before.
did everyone's red color "P" (parked) returned after flashing?
Re: Flash Question
rainy187
Re: Flash Question
Post by rainy187 »
ok, will do that later on tonight
rainy187
Re: Flash Question
Post by rainy187 »
i already sent the feed back
