s300 fuel pump not on with ignition on
Posted: Mon Apr 28, 2025 2:33 pm
I have an s300 and have for about 10 years.
I haven't driven the car in over a year but tried (with new spark plugs installed today) and the fuel pump is OFF with the ignition in ON position.
The car cranks when trying to start it, and the fuel pump turns ON at this point, but the car does not try to start.
Any thoughts or suggestions? I am trying to get this running and driven regularly again. It worked for years before and was only driven every couple of months.
I do not have another ECU to test with as this is the only one I have for it and it is tuned and will not work with the stock ECU.
ECU: P28
S300-v3 board
I can connect with my old hondata app (the free one from years ago), and it reports sensor states just as it had in the past.
Thank you
Dustin
ECU: P28
S300-v3 board
Thank you
Dustin
