K miata
Posted: Sun Apr 27, 2025 1:08 pm
Swapping a NA miata with a k24a2 out of a 08tsx. this will be the second engine going into it as i spun a rod bearing on test drive, replaced the all bearings and main bearings and spun the same bearing again. now i dont know if the motor already had the spun bearing to begin with or not. if i swap a fresh motor from a jdm supplier and throw it in. is it still safe to run it on the 08tsx base tune I was provided by Kpower or should i switch to a 04 as suggested on the kmiata installation guide website. not trying to have this problem happen again. any notes will help. getting the new motor tomorrow and gonna start swapping parts over.
