I was wondering if anyone here can help me dial in my ignition map and help fine tune my parameters as im a bit new to all of this in general.
specs:
-B20Z W/ GSR HEAD
-H.S.L. BLOX CAMS W/Stock cam gears and supertech valve train
-440cc rc injectors AEM fuel rail
-skunk2 pro series manifold w/70mm throttle body
-tri-y headers w/ 2.5in exhaust ,2 resonations and muffler
I've attached 2 datalog files and the map i'm using. Any help/input would be appreciated!
need help with ignition map
Re: need help with ignition map
Log looks really noisy, reduce your rev limiter from 9000 to 7800 to be safe if your going to rev it out. Check all your grounds.
Here is what a log should look like
