Help CF4 Map
oncevisit
Help CF4 Map
Post by oncevisit »
So i just changed my motor mounts and TPS and was putting everything together. I hooked the wrong plugs up on my skunk2 74mm TB. Had the key on and was going to calibrate my TPS and noticed. I hooked the connectors to the right plugs calibrated the TPS but noticed the MAP was reading -28.8psi. The car will not start now. I'm guessing I fried the map sensor. Would this be a good assumption or am i missing something? The car was running just fine prior just bad motor mounts that caused the TPS to get smashed on the firewall.
Current Setup
98 Honda Accord Sir-T CF4
g series 6255 51r mod
KS pistons/rods 10:1
Skunk2 74mm TB
Skunk2 Intake
FIC 1000cc injectors
p28 Hondata s300
Re: Help CF4 Map
IF it is plugged in correctly and still not reading correctly then it was probably damaged by having it wired incorrectly.
