Can you run a NonVtec program on a P28?
Posted: Wed Nov 03, 2004 9:57 am
by sander
The reason i ask this is that i used to have an LSvtec, and now have a b20, i was wondering if i could just disable the vtec pressure and spool and just use the low speed tables of the P28?
Thanks,
-sander
Posted: Wed Nov 03, 2004 3:01 pm
Yes, in the software disable the VTEC pressure and spool, and disable the use of the high speed cam table.
Posted: Thu Nov 04, 2004 6:27 pm
by sander
Great thanks.
-s
Posted: Sat Jan 01, 2005 11:25 pm
by Super-Tuner
how do u disable the high speed cam table or do you just not use it and ignore it?
Posted: Mon Jan 03, 2005 10:48 am
by DaX
You can set the RPM at which the High Speed Cam Table engages at an unattainable RPM...like 11K RPMs.
Posted: Fri Jan 07, 2005 9:49 pm
by Super-Tuner
Cool, also should you check the box under the vtec tab that says non vtec? Im assuming yes. Also what do you do with the iab section just set it to like 8000 like the rev limiter or what
