Page 1 of 2
JDM EP3
Posted: Sun Feb 02, 2025 8:22 pm
by Omarep31027
Can I use a PRB Kpro in a JDM RHD EP3?
Re: JDM EP3
Posted: Mon Feb 03, 2025 11:03 am
What is the original ECU part number?
Re: JDM EP3
Posted: Mon Feb 03, 2025 4:02 pm
by Omarep31027
37820-PRB-A04
2068-302516
Re: JDM EP3
Posted: Mon Feb 03, 2025 5:06 pm
What is the part number of the ECU from the vehicle in question?
Re: JDM EP3
Posted: Mon Feb 03, 2025 5:40 pm
by Omarep31027
37820-PRD-J02
Re: JDM EP3
Posted: Mon Feb 03, 2025 5:42 pm
That is a European ECU so you should not try to use the PRB in it. You should use the PRA to run it correctly.
Re: JDM EP3
Posted: Mon Feb 03, 2025 5:46 pm
by Omarep31027
Sorry it’s a 37820–PRD-j20
It’s a Japan spec EP3 type R body RHD
Re: JDM EP3
Posted: Mon Feb 03, 2025 5:52 pm
You have given 3 different part numbers. Which is it?
Re: JDM EP3
Posted: Mon Feb 03, 2025 5:59 pm
by Omarep31027
Let me start from the beginning. I have Japanese
market right hand drive car. EP3 civic Type R.
I put a K20a2 in it with a Kpro installed 37820-PRB-A02
I assume the car originally comes with 37820-PRD-J02 to run a K20a
My question is am I ok using the PRB ecu
Thank you
Re: JDM EP3
Posted: Wed Feb 05, 2025 9:57 am
There should be a sticker on the underside of the hood with an ECU part number. What does that sticker say? We need to know if it originally had a PRA or a PRD ECU.
Re: JDM EP3
Posted: Mon Feb 10, 2025 10:38 am
by Omarep31027
The only numbers I could find underside of the hood are
87533-PLC-900
The rest was all in Japanese.
Re: JDM EP3
Posted: Mon Feb 10, 2025 11:47 am
Where are you located?
Re: JDM EP3
Posted: Mon Feb 10, 2025 11:48 am
by Omarep31027
New York NY
Re: JDM EP3
Posted: Mon Feb 10, 2025 12:04 pm
A US ECU will only work if the original ECU was PRD. If the original was PRA then it will not work correctly.
Re: JDM EP3
Posted: Mon Feb 10, 2025 3:45 pm
by Omarep31027
Thank you so much for your help. So a base map PRB will work?
