JDM EP3
Omarep31027
JDM EP3
Post by Omarep31027 »
Can I use a PRB Kpro in a JDM RHD EP3?
Re: JDM EP3
What is the original ECU part number?
Omarep31027
Re: JDM EP3
37820-PRB-A04
2068-302516
Re: JDM EP3
What is the part number of the ECU from the vehicle in question?
Omarep31027
Re: JDM EP3
37820-PRD-J02
Re: JDM EP3
That is a European ECU so you should not try to use the PRB in it. You should use the PRA to run it correctly.
Omarep31027
Re: JDM EP3
Sorry it’s a 37820–PRD-j20
It’s a Japan spec EP3 type R body RHD
Re: JDM EP3
You have given 3 different part numbers. Which is it?
Omarep31027
Re: JDM EP3
Let me start from the beginning. I have Japanese
market right hand drive car. EP3 civic Type R.
I put a K20a2 in it with a Kpro installed 37820-PRB-A02
I assume the car originally comes with 37820-PRD-J02 to run a K20a
My question is am I ok using the PRB ecu
Thank you
Re: JDM EP3
There should be a sticker on the underside of the hood with an ECU part number. What does that sticker say? We need to know if it originally had a PRA or a PRD ECU.
Omarep31027
Re: JDM EP3
The only numbers I could find underside of the hood are
87533-PLC-900
The rest was all in Japanese.
Re: JDM EP3
Where are you located?
Omarep31027
Re: JDM EP3
New York NY
Re: JDM EP3
A US ECU will only work if the original ECU was PRD. If the original was PRA then it will not work correctly.
Omarep31027
Re: JDM EP3
Thank you so much for your help. So a base map PRB will work?
