Hybrid Racing KPro Question EP3
Posted: Wed Jan 01, 2025 6:49 pm
by EP3_Zae
So I send my stock ep3 PNF to Hondata via the Hy rid Racing site. I am getting the clear security error and upload error so I’m assuming this was an instillation error on my part. Note I am swapping a Tsx K24a2 into my EP3. Should I contact Hondata directly or ask Hybrid about how I can get the ECU looked over? I don’t have any local friends or family with a k swapped car that could test the KPro in. Oh I also repined the crank sensor so KPro would real correctly, my map sensor is also reading -28. Where should I start?
Re: Hybrid Racing KPro Question EP3
Posted: Thu Jan 02, 2025 10:43 am
What is the serial number that is on the K-Pro board inside the ECU?
Posted: Thu Jan 02, 2025 1:28 pm
by EP3_Zae
64125?
Posted: Thu Jan 02, 2025 4:06 pm
What has changed in the vehicle since the last time it was working?
Posted: Thu Jan 02, 2025 4:54 pm
by EP3_Zae
Full motor swap, from k2a3 to a k24a2. Still have oem ep3 harness just pinned at crank shaft and map sensor extension. I also have a type s harness if need be
Posted: Thu Jan 02, 2025 4:57 pm
by EP3_Zae
Since the swap & KPro I have yet been able to upload a base map due to the security clear error and upload failed.
Posted: Thu Jan 02, 2025 5:03 pm
It sounds like something may have been wired incorrectly and damaged the ECU, K-Pro or both.
Send an email to support <at> hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
Include a link to this thread.
