Why Knock Level is like this?
Posted: Sat Nov 23, 2024 10:51 am
by saltyrabbit90
Hello.. I have been enjoying the Flashpro a ton since i got it.
However, i decided to log my car after 6 months of being tuned.
The issue:
My knock level is confusing me. It starts at 70%-84%, then stays at 100% for the rest of the drive after a WOT pull from 20-50mph in 3rd gear.
Car:
2007 Honda civic si with Hondata CARB stock tune. No modifications were done to the car except the tune. 105,000 miles. No issues with AFR.
Knock count total is 126 in a 1 hour drive. Knock count climbs by about 14 knocks after WOT at 2900RPM in 5th gear.
Should I be worried? Could this be false knock? Car is not exactly new, so i thought it might be other mechanical noise.
Any insights are appreciated. Thanks!
Datalog is too big though, so i cant attach the full log here. Here it is on google drive : https://drive.google.com/file/d/1gAv2ZD ... drive_link
I attached a minified version of it here too as well.
Re: Why Knock Level is like this?
Posted: Mon Nov 25, 2024 9:03 am
HAve you tried reducing the timing in the area it is detection knock?
What octane fuel are you using and what brand is it?
Posted: Tue Nov 26, 2024 11:21 am
by saltyrabbit90
I am using hondata CARB , which i think does not allow editing tables.
I use 91 fuel in Texas.
Also, i forgot to mention that i use solid mounts on lower rear and upper passenger mount.
Thanks.
Posted: Mon Dec 02, 2024 3:07 pm
Then you will not be able to make any adjustments to this.
Posted: Fri Dec 06, 2024 10:18 am
by saltyrabbit90
So what do you think the culprit in this case? Just bad fuel? Or mechanical noise?
I have a hard time believing it is a real knock.
Posted: Fri Dec 06, 2024 11:26 am
What brand fuel is it?
Posted: Fri Dec 06, 2024 5:46 pm
by saltyrabbit90
Chevron
