Near engine stall when pushing in clutch at stop light
Posted: Fri Nov 08, 2024 8:00 am
by dennis si
I purchased my 5th 8th gen Si! 09 FG2 with 93k miles and my first forced induction k20. 62/62 turbo. Tune is not bad. afr's great under full throttle. Having an issue when coming to a stop and pushing in clutch engine almost stalls. Only thing I could find that may be the culprit is in settings, lambda overlay, options throttle min is set to 4%. Would changing that to 0 maybe fix? Appreciate whoever can take a look.
comingtoastop.fpdl
Re: Near engine stall when pushing in clutch at stop light
Posted: Fri Nov 08, 2024 10:07 am
Does it have a lightweight flywheel?
Posted: Mon Nov 11, 2024 6:54 pm
by dennis si
Stock flywheel with fx400 clutch. Throwout bearing is on the loud side compared to my 4 previous Si's but I'm guessing stage 4 TO bearing? Or whoever installed it didn't use high temp grease on the input shaft. Going to pull the trans inspection cover and see how it looks and check for up/down movement of fork/bearing.
