Ok I guess I have a very vague and newbie Question, I have a Socketed P28, now using a "Skunk2" Program. I have just finished My build, ( fully built D16z6 with T3T4) My question is how exactly does the S200 box "attach" it self to the inside of the ECU? I mean I see the Wires that go thru the actuall casing, but hows does the Rom chip work, I take it that it would replace my Skunk2 program obviously, but I mean How eactly does it all come together? Will someone please take a min and clear this up for me.
Thank you very much guys!
Newb needing some insight.
civiksiracer1
94 Ej2
Fully built Z6
T3/t4
looking for 450 fwhp
Fully built Z6
T3/t4
yes can use the same ecu and the hondata chip will replace the current skunk2 program that you are using now..
as for hooking up the s200 box, you need to have someone install meaning solder the 4 pin connector that is required for hondata to communicate w/ the ecu. once you have the connector installed you have a wire harness from the hondata blue box to the ecu and thats it..
