2005 Acura RSX type s
K24A2 engine
2005 RSX type s transmission 6spd
2005 engine harness
KPRO - 67779
37820-PRB-A05
2068-515036-0I19
Hondata k-series programmable ecu editor
Version 4.6.1.0 Build 4083
Had my ECU sent to hondata in the past two weeks, unsure of exact dates as I had to send through a dealer.
Problem:
I have the code 56 DTC p0010 description vtc solenoid malfunction.
I had a rbb solenoid in it, replaced with pnc solenoid both are new. I had an ecu with ktuner, I switched back to it and no vtc code so wiring seems to be good.
2005 RSX-S K24A2
Ganjastorm
Re: 2005 RSX-S K24A2
Problem solved. Had to rewire vtc ground (black) to the new kpro 02-04 ecu by pinning to B23.
For anyone who needs to do this, you can remove a pin from pretty much any OBD2 Honda ECU harness (01-06) there are different sized pins, so if a pin you remove is too big for the b23 port, try another.
Also I’m using the 15830-PNC-003 VTC solenoid.
