k20/k24 With DC 2.2 Base Map
Posted: Mon Sep 30, 2024 4:40 pm
by vha91
Hello, I was wondering if someone would be able to send me a base map calibration for my car? I should be done assembling the engine and installing it in the car this weekend. I would like to get the base map to start the car up and be able to drive to a tuner. Here is my setup below:
JDM k24A Bottom Block / K20A2 Head
Drag Cartel 2.2 Cams
RBC Intake Manifold
Skunk2 70mm Throttle Body
3.5" Intake
DTR 4-1 Reverse cone Header
Fuel Injector Clinic 650cc injectors
43 PSI fuel Pressure
Walboro 255
I apologize as I currently don't have the injector data paper on hand with me since the car is in my buddies garage. I can get the data if completely necessary.
Re: k20/k24 With DC 2.2 Base Map
Posted: Mon Sep 30, 2024 6:03 pm
by CalibratEd
Have you reached out to your tuner to see if they can provide you a base calibration to get you to their shop?
-Ed
Posted: Tue Oct 01, 2024 9:05 am
by vha91
No, I just wasn't sure which tuner to go with yet since there is several around my area haha.
Posted: Tue Oct 01, 2024 4:51 pm
by CalibratEd
When you decide who you are using as as a tuner, I suggest you reach out to them.
In the mean time post the calibration you are running and a datalog. I can take a look at it and let you know how the car is running.
-Ed
