9thgen crank enrichment per engine coolant temperature tables
Posted: Mon Sep 16, 2024 8:17 am
by CalibratEd
Hello Hondata,
I am inquiring regarding crank enrichment tables for the 9th gen civic. I am currently working on a car that is having hot start issues. I realized there are no tables to adjust cranking fuel per coolant temperature. I came across this thread showing screenshots of the tables I am looking for. viewtopic.php?t=14301 Are these tables not available on the 9th gen civic? Below are images of both 8thgen and 9th gen tables
Current FlashPro version:4.2.6.0
8th gen Tables
9th gen tables
Re: 9thgen crank enrichment per engine coolant temperature tables
Posted: Mon Sep 16, 2024 11:52 am
The 9th gen does not have the same tables in the ECU. It most likely compensates via AFM reading.
Posted: Sun Sep 29, 2024 7:41 pm
by CalibratEd
Spunkster wrote: Mon Sep 16, 2024 11:52 am The 9th gen does not have the same tables in the ECU. It most likely compensates via AFM reading.
Thank you. I will give that a try.
-Ed
