no connection with the control unit, at 7000 rpm, when I write logs
WolkovAI
Post by WolkovAI »
I write logs in third gear, accelerate to the engine cut-off (8600 rpm), logs are written up to 7000 rpm and the Hondata freezes, returning only if pulled out of the USB connector. I changed the laptop, USB cable, nothing helps\
Acura RSX K20k24 Hondata K pro
Re: no connection with the control unit, at 7000 rpm, when I write logs
Are you using resistor or non-resistor spark plugs?
WolkovAI
Post by WolkovAI »
Spunkster wrote: Tue Sep 03, 2024 12:14 pm Are you using resistor or non-resistor spark plugs?
NGK
IZFR6K11S I don't use a resistor
Resistor type spark plugs must be used.
WolkovAI
Post by WolkovAI »
Spunkster wrote: Tue May 06, 2025 9:05 am Resistor type spark plugs must be used.
I removed the board, cleaned it from dust, installed it back, no more problems, works great
