Switching Kpro boards
Posted: Fri Aug 09, 2024 9:27 am
by Boostjunky
Hello,
Long story short, I have 2 Kpro ecus with Kpro v4 already installed on both. I am trying to single out an issue I am having. The issue is not relevant to this question. My question is;
Am I able to remove the Kpro v4 board from my PPA-A03 ecu, and remove the Kpro v4 board from a PND-A01 ecu, and swap the Kpro boards without any further modification. More specifically, the Kpro board from the PND ecu will be swapped over to the PPA ECU for my testing needs. Is it really as simple as swapping the boards over or are there further steps that need to be taken once the boards are swapped? And if there are further steps, what are those steps? The same tune calibration is already loaded on both boards.
Thank you in advance.
Re: Switching Kpro boards
Posted: Fri Aug 09, 2024 10:50 am
Yes, you can swap them to test.
