Page 1 of 2
FA5 Supercharged launch limiter
Posted: Mon Aug 05, 2024 7:53 pm
by Jmags01
When down loading tunes with boost capabilities you loose the launch disengauge speed and the full throttle shift option. Is there a base tune out there that has those capabilites?
Re: FA5 Supercharged launch limiter
Posted: Wed Aug 07, 2024 9:22 am
by CalibratEd
Post the file you are using. I am not sure what you mean by boost capabilities.
- Ed
Posted: Thu Aug 08, 2024 10:34 am
by Jmags01
In the available boost base tunes the Launch speed limiter for MPH disengauge and flat foot shifting go away in the Rev Limit options. I attached one of each base files. In the rev limit section you will see the differance.[attachment=0]launch disengauge speed and full throttle shift available.
Posted: Thu Aug 08, 2024 3:52 pm
by CalibratEd
I am not sure what is missing. It seems Launch speed limiter for MPH and flat foot shifting options are available in both files provided.
- Ed
Posted: Thu Aug 08, 2024 5:41 pm
by Jmags01
Thats odd cause it doesnt look the same on my end.
Posted: Thu Aug 08, 2024 5:54 pm
by Jmags01
This is what i see on any of the MAP base tunes.
Posted: Fri Aug 09, 2024 9:08 am
Posted: Fri Aug 09, 2024 10:40 am
4.2.3 26 Feb 2024
Posted: Fri Aug 09, 2024 12:03 pm
by Jmags01
Thats the version Im useing 4.2.3 feb 2024
Posted: Fri Aug 09, 2024 12:37 pm
Your software is out of date and needs to be update to the newest version.
https://hondata.com/software?route=info ... nformation
Posted: Fri Aug 09, 2024 1:50 pm
by Jmags01
I downloaded the new software and it didnt change the issue that im having. It did add a new mod drop down and thats about it.
Posted: Fri Aug 09, 2024 2:43 pm
The calibrations you have posted show the correct things when opened.
When you re-install the software, make sure that everything is checked when installing it.
Posted: Fri Aug 09, 2024 3:51 pm
by Jmags01
I uninstalled Flashpro and made sure all boxes were checked for all vehicles when reinstalling. Still see the same thing, MAP based tunes dont have the same rev limit options.
Posted: Fri Aug 09, 2024 3:55 pm
by Jmags01
And it would probably help if i didnt originally post two of the same files. Here are the differances in files.
Posted: Fri Aug 09, 2024 4:00 pm
What is your FlashPro serial number?
