01 civic k20a swapped
rsxguy
Post by rsxguy »
wondering if anyone can look into this tune for me the guy i bought it back from had it tuned and it drives fine but at idle it surges down to like 400 rpm and will hold there for a second before it goes back up also when i start the car in the morning and let it warm up when u press the gas lightly the car shuts off u have to keep it above 2k rps or else it gets boggy any help would be apreciated im going to attach the tune and the datalog its a k20a with 600cc injectors,rbc manifold, ktuned 70mm throttle body,kai,rsx type s 6 speed trans,i also just installed an acuity tps because i thought that would help,i also tryed to just install a fresh basemap from kpro but the car didnt even want to idle
CalibratEd
Re: 01 civic k20a swapped
Post by CalibratEd »
I am not sure if you meant to upload these files. You uploaded a calibration from kpro but a datalog from the S300. The tune seems to have been modified for pops and bangs. The fuel tables look like they are all over the place. I suggest you start with an unmodified calibration. Otherwise you may chase your tail trying to dial it in.
- Ed
Instagram: calibrated.tuning
rsxguy
Post by rsxguy »
my bad those were for my hatch lol i just installed an afr sensor in my em2 and i will upload the datalog in a few mins
rsxguy
Post by rsxguy »
ok ran into some trouble installing the afr sensor so i cant use the analog inputs because its kprov3? so where should i put the signal wire? i have a prd ecu. i have the red wire going to 12v switched power on the fusebox and ground going to battery
Are you trying to run in closed loop with an aftermarket 02 sensor?
rsxguy
Post by rsxguy »
right now i have no 02 sensors only the afr gauge
You can't read the AF without an O2 sensor.
rsxguy
Post by rsxguy »
so should i just get rid of the aem wideband and get a stock 02 sensor
Does the gauge have it's own wideband sensor?
rsxguy
Post by rsxguy »
yes
rsxguy
Post by rsxguy »
i just cant connect it to kpro thru the anolog because i have v3
You cannot run closed loop from an aftermarket wideband with a v3 K-Pro. It can only be used for datalogging.
rsxguy
Post by rsxguy »
that is what im trying to use it for...im asking is there a way to hook it up to kpro v3 for that i tryed using the analog inputs but it wont let me
rsxguy
Post by rsxguy »
idk if u cau see whats going on just from this im holding it at 1500rpm and this is the studder does it while im driving too
You cannot run closed loop from an aftermarket wideband unless you have a version 4 K-Pro.
