01 ITR and s200 Q
TypeRPaul
01 ITR and s200 Q
Post by TypeRPaul »
I want to get the s200 unit but what else do i need to buy? Here is what i think i need:
-P28 ECU
-Skunk2 obd1 harness adapter
-s200
Is this it or do i need something else?
Also will the s200 work with a Toda Individual Throttle body set-up?
Jaker
Post by Jaker »
Your OBD adapter does not have to come from Skunk2. It could be any of the reputable brands available from the various resellers (including Hondata).
Carchitect
Post by Carchitect »
The components you have selected would work just fine. However, since the inndividual throttle body conversions utilize an exceptionally leagr plenum they will have the opportunity to flow a lot better than a barrel style plunum. Due to this I would suggest you go with at least 330cc/min injectors if not larger to feed the fuel you need. You also may need to get creative with a MAP sensor canister that utilizes four vacuum hoses from each intake port to give a smooth vacuum signal to the MAP sensor.
Joe.
Experience is what you get when you don't get what you want
08 IS350 Sport Package, Levinson, Nav, Radar cruise.
94 JZA80 6speed undergoing major weight reduction AKA 911 GT2 killer.
90 DA9 B18C5 retired auto-Xer
