Here's the deal, my 96 accord (OBD2 car), and we converted to OBD1 and are using Hondata S200B on it. I have a skunk obd2b-obd1 ecu conversion harness, p06 ECU, and once the car is started, after about 10 seconds it throws a code 9 (cylinder position sensor)
We thought maube it was a bad harness, the continuity on it is fine, the harness seems fine after running countless tests and checks on it.
We then thought maybe it was the ECU or accord base map that we have burned to it, so we took the ECU out, plugged my ECU into my buddies 92 GSR without the conversion harness and he gets no code. ECU works fine in his car.
Then we took my stock obd2b ECU and put it back into my car, and we dont get a code. We're thinking it has something to do with the Distributor... Maybe the ECU is looking for something on the car that the ECU doesn't have???
Does anyone have any ideas????
***Need help asap!!! Getting code 9......***
96accordEX
